標(biāo)題: 本田S2000深度改裝亮相街頭 [打印本頁]
作者: firemike123    時(shí)間: 2014-6-11 16:19
盡管改裝后,這輛車已經(jīng)沒有S2000的標(biāo)志,但是這并不影響被認(rèn)出來。每年的一些改裝展上都會(huì)少不了S2000的身影,今年也不例外,最近的北京改裝展也有吧,問題就是驚喜度了
英文改裝清單:(看懂多少看自己的造化吧)
Engine:
J’S RACING Complete Engine
TODA RACING A2 Camshaft
AP1 Genuine piston(Lightweight processing)
TODA RACING Lightweight crank pulley
J’S RACING Full exhaust and intake (Air intake,intake panel,big throttle,EX manifold, straight cat pipe,exhaust muffler)
J’S RACING 1.5way LSD and 4.444 Final gear
EXEDY HYPER Single clutch
VF J’S RACING HYPER ECU
J’S RACING MAX COOLING radiator
J’S RACING Strat brace bar
J’S RACING Oil catch tank
NGK Iridium plags ?8
J’S RACING Mission and engine mount
Interior:
RECARO TS-GS and RS-GS TAKATA MPH-341 Harness
MOMO steering wheel
quick release
RAFFIX GTC-R Flip-up
Defi Water and oil TEMP
Oil pless meter
amis meter panel
J’S RACING Titanium shift knob
Special audio control panel processing
Exterior:
J’S RACING Type GT Wide Body Aero System(with full option parts)
(Special orders full carbon rear bumper and rear fender)
J’S RACING hood and GT wing
Craft Square TC mirror
VARIS Carbon trunk
MUGEN CIVIC RR Genuine back fog
AP1 Genuine Pillar cutting sheet
Beloff Hi and Low HID KIT(6000K)
Wheels and tires:
RAYS TE37SL
18inch x 10.5J+15(and 5mm Spacer)
18inch x 11J+18(and 25mm Spacer)
GOOD YEAR EAGLE RS Sport
F#235/40R18 R#265/35R18
J’S RACING Lug nuts Long
Suspension/Brakes:
J’S RACING×SHOWA Special damper
J’S RACING×swift 24kg Coil Springs
J’S RACING Front camber joint S2
J’S RACING Pillow tie-rod
J’S RACING Pillow Upper suspention mount
J’S RACING Rear Roll Center Adjuster 20mm
J’S RACING Pillow Rear Controll arm
J’S RACING Side Inner breath bar
J’S RACING Drive Shaft Spacer
J’S RACING Rear Tower breath bar
J’S RACING Lower Arm Bar
J’S RACING 6POT Brake caliper system
J’S RACING Rear big rotor system SEIDO-YA Brake pads
作者: q055    時(shí)間: 2016-3-29 22:17
真造型.我的也要改一下
